I don't want to go to the expense of taking the chassis cert from 8.50 to 7.50, so I'd like to hit it with a small shot of spray and run right at my chassis limits. Then I'm done. I'm pretty sure a small Monty shot should get me yelled at for going under the cert
If I keep the car much longer I'll slow it down a little with a pump gas motor and turn up the spray. Then I can drive it more on the street and still go as fast at the track.
