I`m assuming the sway bar was bolted to the car before sound deadener(undercoating) application?
Is your car a undercoating optioned car? Or just the standard undercoating?
My 71 R/T has lots of undercoating on the sway bar. But not completely. The frame brackets are pretty much covered. Including the self tapping bracket to frame bolts.
thanks autox,I will be applying just the standard sound deadener in the wheelwells to the car........
