Originally Posted by Cab_Burge
Does a Molnar crank and rods with CP pistons count? whistling
I'm not sure which part fail first yet, block or piston confused
But it wasn't the rods or crank though uptwocents
Yes it counts - in my book.
Seems, looking at past posts, guys here argue that horsepower is not a factor in rod failure, more along the lines of engine speed and piston weight.
Yet it still gets thrown in the discussions.
Molnar explained rod failure and how to arrive at the conclusion that the engine broke the rod/s due to over speed.
