Are you planning to do the work yourself?
Yes, Andy. I am doing the fabrication. The backhalf 4 link is installed and verified to be square within the body and the factory LCA points.
If you're going to do the work yourself and have never done this kind of work before then I'd suggest buying a kit. Or hiring a chassis guy to help you with the project. Lots of stuff has to be put together correctly on the front suspension for the car to be safe at speed.
I am definitely getting the kit from Alston. They offer both types, which is why i was asking for pros and cons as well as which one is more suitable for my application. After reading everything and considering budget in future for upkeep and maintenance: i think i will be going the A-arm kit.
Thank you.
