I'm having interference problems between the bottom of the pistons and the crank counter weights on my Ford 351W stroker motor I'm building for my 1940 Ford Tudor whiney
I've never had a problem with any of the Mopar, BB or SB stroker motors I've had machined and balance shruggy
I'm going to try and have it fix here locally by a shop that does a lot of Fords and hope it won't take a lot of welding or heavy metal added onto the crank after getting the clearances needed luck
