.050-.060 is preferred safe clearance. Always do the counterweights when you can, much better way. ( all depends on bob weights too)Also, if you just go all crazy with a die grinder and dont do a good job of working that down, and smoothing it all, every one of those marks is a potential stress riser, aiding to a crack down the road.If you can see a sand mark, or heavy gouge, its a stress riser.
RIP Monte Smith
Your work is a reflection of yourself, autograph it with quality.
WD for Diamond Pistons,Sidewinder cylinder heads, Wiseco, K1 rods and cranks,BAM lifters, Morel lifters, Molnar Technologies, Harland Sharp, Pro Gear, Cometic, King Engine Bearings and many others.
