Same box here - Pertronix digital HP, and I set mode 9 to 4000 for "magnetic trigger falling edge". Still using stock dizzy but I replaced the Mopar ecu with this box. Timing was nearly same as it was before. Using this box because it has start retard which is mode 7- and I set that to 4500. My initial is 24 degrees.
