Thanks!. However this makes me wonder. Looks like the falling edge is the sharp one. Wonder why the Pertronix won't start the car set to falling edge trigger. The rising edge in that scope pic is not the one you would not want to trigger off from what I believe.
You can set the box to trigger off a rising or falling edge signal. Is that the same as swapping the wires to the dist? I'm not sure it is
