Expect your boost numbers to drop with those heads and cam.
You likely need to remind the guy that boost is resistance to flow. The new setup will use more air so less of it will stack up in the intake. You're always on the right track when you make more power with less boost.
He has to get out of the mindset of talking boost numbers. Someone else will be packing more boost and make him think he's missing out.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind. - Stu Harmon
