Final compression ratios in excess of 12.4:1 are not recommended for use with "pump gas." The higher the final compression ratio, the higher the octane rating of the fuel must be in order to help prevent detonation and serious engine damage.
The formula for calculating your exact final compression ratio is as follows:
Final Compression Ratio (FCR) = [ (Boost÷14.7) + 1 ] x CR
Boost = Maximum blower boost
14.7 = psi at sea level
CR = engine compression ratio
Altitude plays an important role in determining compression ratios. If the altitude in the area where you normally drive is significantly higher than sea level, then your compression ratios will also vary. To determine the effects of the altitude on a calculated compression ratio, use the following formula:
Corrected Compression Ratio = FCR - [ (altitude÷1000) x 0.2 ]
= Pump Gas = Good Gas
