Quote: looks real good ron ! do you have any thoughts on fabbing a steering column ? i see you have a quick release setup on yours. i was thinking on the line of 1 3/4 tube[or so] for the jacket and 3/4 or 1" for the shaft. what did you use for bearings ?
I used a lower bearing from a dakota column I had here for the top and a bearing from some other mopar column I had laying around for the bottom and a piece of tubing from something else and made them all work Ron...
