iagree
But will clarify, A paper filer before the pump may restrict the flow a small amount and technically require a bit more vacuum (which is negative pressure)
no such thing as "negative" pressure. it could be described as "negative" but it is truly "opposite" or "absence" of pressure........... whistling biggrin argue work catfight stirthepot
just yankin' yer chain ! my one close buddy and i argue this point every chance we get just because. laugh2
beer
