Thanks everyone for the replies. The motor is a 440, the pump is a stock replacement mechanical unit. I'm going to check for vacuum at the pump as suggested. The sending unit doesn't have a sock on it but is over 20 years old, as is the rubber line from the pump to the steel line, and rubber line from the sending unit to steel line.
