Hello, can a fuel sending unit for a 67 B body be removed from the gas tank without removing the tank? I have a 67 Coronet R/T that isn't getting fuel to the pump. I replaced the pump and filter. I suspect a blockage in either the line or the sending unit. Thanks.
