Originally Posted by challenger451ci
Originally Posted by birdtracker
they do everything in house. They line bore also! By going to the 440 mains the bearing selection is alot more. Birdtracker
Very good! I had Ohio fix a couple Chebby cranks in the past and was very happy with the way they came out. I've been talking to Weston Machine in NJ about bushing the lifter bores for me and I figure they can do the mains while it's there.
Ohio crank fixed the thrust surface on mine for $200, their crank too. Quick turn around too
