Originally Posted by CompWedgeEngines
Thanks Jim
I was looking for tuning parts ( needles and jets) for a restoration engine ( with hotter cam and bowl blend) . The stock restored AVS, was killing the power by almost 60HP. We drilled some jets from another carb I had, changed some rods, picked up 60HP. We knew the carb was bad, as we tried a 650 Bo Laws carb, and the power went right back up. In the end, we just had to make our own stuff.
Thanks again for the offer,
What Factory # Carter AVS are you running ?
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
