I'd put an ad in here/fabo or locally for a parts carb with the intact pieces you are after & if need be the eddy performer 2 step rods/primary jets can be used. All OE avs's are lean due to the discombobulated emission standards of that era that Ma & everybody else were scrambling to keep up with.
