I run a solid mount on the drivers side. You can't tell anything is different from the rubber type.
Member farmboy made them for the '63 and after they were painted black they look stock.
He made both sides but I only used the drivers side.
'63 Dodge 330
11.19 @ 121 mph
Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
10.01 @ 133mph with a 250 shot of nitrous an a splash of race gas. 1.36 60 ft. 3,700 lbs.
