I have a Hydratech system in my Belvedere. Going from manual brakes to power was a huge step but the car stops so much better with no other changes.
No problems with the system and the install went without any issues.
With disc up front drum in the rear I did need to adjust the proportioning valve as the drums wanted to lock up instantly with the extra pressure but it dialed in quick and works great.
