Install slider into frame rail With a little rattle can on top... I have made shims that go in under the bolt in slider to help scale the car there is 6 lb between the left and rear tires on the starting line ready to go.. just a little Backyard Boogie
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
