Important: When purchasing a thermostat always consider the maximum amp draw. Some thermostats are not designed to
properly handle 25 amps.
just now this sentence took my attention... why Delare instructions gets worried about that ? the load is handled by relays not straight for the thermostat/temp sensor switch!!! not even being activated by positve from the thermostat/temp sensor switch.
just as a reminder... My diagram shows it being triggered by negative from thermostat/temp sensor switch, opposite to what Delare shows.
