AAAAAAAND, YOU CAN ALLWAYS INSTALL AN OVERRIDE SWITCH somewhere down the dash, for one of the fans ( either one ) with just ground signal spliced into the 85 terminal of any of the fan relays ( usually, the secondary fan ), or even spliced into the 87 terminal of the fan clutch signal relay
With a Charger born in Chrysler assembly plant in Valencia, Venezuela
