I’m not going to push it hard enough to find out. My only saving grace may be that the pressure is jacked so high that damage has been kept to a minimum. If I’m satisfied that the kickdown is functioning I’ll move on to the valve body. Not surprisingly there are a few other issues with the car that also need to be sorted out before it hits the pavement again. Nothing I can’t handle but it all takes time.
