It appears the V8 rocker is too short to work. Those Crower rockers are self aligning so wouldn't need guide plates but pushrod length would be an unknown. New stock lifters should be fine.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion.
2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
