Originally Posted by gregsdart
Deckaids ago i used a cutter that you put in place of the valve , secure the head to the motor with a couple of bolts and use a drill to cut each piston. It made a mess but grease in the crevice of each piston/ cylinder wall allowed me to clean it up fine. Wow, that must have been 45 years ago now. Crane or Comp or Isky had the cutter, can't recall who.
I did the same thing years ago but this engine is still on a stand and I can pull the pistons
to put on the mill
wave
