I just did a Milodon high flow pump and milodon high flow stat and it helped a lot! I started with just the pump, when I added the stat it was very noticeable. 10-15 degree drop. Dependent on ambient Outside air temp.
My engine runs about the same temp even on a 94F day, which I don't do much of since I didn't put a/c in the Dart
Lately it's been in the mid-80's with identical results.
I guess I did it backwards (stat first). I'll bet there is a six-vane pump in there when I get it out. But maybe not!
I've been looking at pumps and was leaning towards the Milodon high-flow - until I saw some of the reviews on Amazon and Summit
