Originally Posted by dragon slayer
Does center link pivot on the pin? Did some one spot weld the square end to the bracket?
That’s part of my concern - the pin is seized and there is limited travel for the pedal link and booster/master cylinder pushrod end.
I’m going to soak it and do other stuff, hopefully I don’t have to drill it out but will if I have to.
