All 3 gauges are dependent on the 5 volt feed from the limiter. Two simple tests would to verify your oil pressure with a mechanical gauge and a pyrometer on the coolant or a mechanical gauge. I have the tester for the gauges. I can measure the readings and you could use resistors to duplicate my testers E-1/2-F values.
