Looks good! I always liked single stage paint, but now I like using base/clear much better.
Thanks, I finished the cab yesterday, no pictures, have to start unmasking today and then check for touch up needed areas. I tried base coat clear coat once but jacked up the cut and buff so I haven't shot it since, on a side note I did figure out why the truck was running bad after I installed the fuel system
seems when a 31 gallon tank is bone dry 5 gallons of gas will not cover the pick up...so yes, the pick up was sucking air and a little bit of gas
