don't think it's an Edelbrock carb you have there, 9636 comes up as a pushrod set for Edelbrock.
Probably a Carter Competition Series AFB 9396S.
According to the info I have the small nipple closest to the linkage is full time vacuum, the small nipple closest to the choke is ported vacuum.
Link to the Edelbrock carb manual, shows the same as the Carter as far as which nipple is what
http://old.edelbrock.com/automotive/mc/carburetors/pdf/carb_owners_manual.pdf
