Originally Posted by lewtot184
Originally Posted by Sniper
don't think it's an Edelbrock carb you have there, 9636 comes up as a pushrod set for Edelbrock.
Probably a Carter Competition Series AFB 9396S.
According to the info I have the small nipple closest to the linkage is full time vacuum, the small nipple closest to the choke is ported vacuum.
Link to the Edelbrock carb manual, shows the same as the Carter as far as which nipple is what
http://old.edelbrock.com/automotive/mc/carburetors/pdf/carb_owners_manual.pdf
you're correct. the nipple next to the linkage is full vacuum. ported vacuum is above the throttle blade (passenger side), full vacuum is below the throttle blade, (driver side). no vacuum from either says something is screwed up.
This was a universal replacement / performance type carburetor. Note the two small nipples either side of the PCV, both are ported vacuum, the right for vacuum advance, the left for EGR, note 50 & 51.. Also note the electric choke and vapor return line.
Attached PDF document
page 22.pdf (28 downloads)
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
