133 mph at 3900 lbs in a car shaped like a barn door is pretty decent. Your ET and MPH are pretty close to what the chart calls for so it looks like your chassis is working good. Should be a fun ride and I'm sure you'll pick up some speed when you get a nice weather day. Come out here to Oregon when the weather is 70 degrees with DA of 100 feet and it will run great!
