Nothing has changed, Penn Grade is the same as Brad Penn, which was the same as the old Kendall. Same oil it has been for years, no reason to change just because the name is different.
AS per Ted's question. For what you are doing I don't think I would worry too much about what oil is in it, but not sure Id change it that often either
