Bias or radial tires?
Same thing on the OP
The tire pressure will make a huge differences on when they move or don't
I use to mark my rims and tires at the tire valve and swap sides on both types of tires tubeless with no screws, The bias tires would move some at first and then move back when swapped to the other side. I don't remember the radials moving very much at all either side or either way
I never tried adhesives on any of my tires , I have a old all mechanical tire machine that I mount all my slicks on, I inflate them to between 20 to 30 lbs. and let them sit overnight or longer before putting them on the car to seat the tires as well as stretch the carcasses as much as possible before measuring the circumferences and adjusting the pressures to get the same circumferences within 1/4 inch of each other
