Re: Bleeding Brakes, without a helper
[Re: Grizzly]
#2779337
05/29/20 06:54 AM
05/29/20 06:54 AM
Posts: 4,920 new berlin wisconsin
Mr T2U
you are correct. air bubbles will rise, basic science.
why this is irrelevant is the next pump of the brake pedal 10 seconds later this air bubble will be pushed out before it has time to rise naturally to cause problems. also when you bleed like this the line is curved above the bleeder before it goes into the bottle. the air bubble will stay in the middle of the line and not go back into the bottle, also basic science. the only way it can rise back up into the caliper is if the bleeder is at the bottom of the caliper, and you don't want that.
i have bled a lot of brakes with a hose attached to the bleeder and the other end is submerged in brake fluid in a bottle. it's irrelevant weather the bottle is above or below the bleeder. it's more important that the hose stays submerged in the brake fluid than weather the bottle is above or below the bottle. some people argue that it's better to have it below the bleeder. this way you can see air bubbles trapped in the line to know if the air has been pushed out. others argue that it's better above for the reason why you stated. i say it's irrelevant. hook the bottle in the easiest way you can as long as it doesn't fall exposing air to the line that should be submerged.
perception is 90% of reality
Entire Thread
QuickDodge
05/26/20 12:02 PM
NachoRT74
05/26/20 12:05 PM
dOrk !
05/26/20 12:14 PM
jlatessa
05/26/20 12:49 PM
dOrk !
05/26/20 12:59 PM
NachoRT74
05/26/20 03:07 PM
RapidRobert
05/26/20 03:17 PM
moparx
05/26/20 04:05 PM
John_Kunkel
05/26/20 06:39 PM
fourgearsavoy
05/26/20 01:26 PM
mopar97
05/26/20 01:41 PM
justinp61
05/26/20 12:08 PM
mopar97
05/26/20 01:20 PM
NachoRT74
05/26/20 03:16 PM
70sixpkrt
05/27/20 02:29 AM
Mr T2U
05/27/20 10:47 AM
05/27/20 12:48 PM
fourgearsavoy
05/27/20 09:39 PM
Guitar Jones
05/27/20 09:46 PM
fourgearsavoy
05/27/20 10:13 PM
5thAve
05/27/20 10:29 PM
dOrk !
05/28/20 12:39 AM
Guitar Jones
05/28/20 01:37 AM
Mr PotatoHead
05/28/20 01:44 AM
kentj340
05/28/20 04:07 AM
Guitar Jones
05/28/20 08:59 AM
Mr T2U
05/27/20 10:37 PM
mopar97
05/28/20 04:23 AM
AndyF
05/26/20 07:32 PM
mopar97
05/26/20 08:00 PM
AndyF
05/26/20 08:40 PM
None2Slow
05/26/20 11:30 PM
BDW
05/26/20 11:36 PM
Guitar Jones
05/27/20 12:34 AM
Cab_Burge
05/27/20 01:34 AM
Mr PotatoHead
05/28/20 01:42 AM
mopar97
05/26/20 08:06 PM
5thAve
05/27/20 10:48 PM
Grizzly
05/28/20 05:05 AM
Grizzly
05/28/20 05:10 AM
Cab_Burge
05/28/20 06:14 AM
Grizzly
05/28/20 06:29 AM
Cab_Burge
05/28/20 04:39 PM
fourgearsavoy
05/28/20 07:16 PM
Grizzly
05/29/20 02:30 AM
NachoRT74
05/29/20 10:54 AM
Mr T2U
05/29/20 10:54 AM
NachoRT74
05/29/20 11:01 AM
Grizzly
05/29/20 12:25 PM
fourgearsavoy
05/29/20 12:37 PM
NachoRT74
05/28/20 03:07 PM
