If I was designing a fuel system for a fast carb car I'd probably use a high pressure pump and have the regulator before the carb. Then you have high pressure up to the front and low pressure after the regulator for the carbs. If you are using a low pressure pump then I don't think it matters too much. In that case I'd just follow the instructions and assume that the mfg knew what they were doing.
