I'm running hydraulic roller lifters on a street solid roller cam right now. It runs good but the idle is much rougher. Oh yeah...... I also run solid lifters on hydraulic cams. What? Am I the only one who does this crazy stuff? Well I don't think this was a street cam despite the conservative lift so since I need to get this together and can't afford to waste a $450 lifter set I wussed out and ordered a hydraulic roller from Utawesome Performance. His grinds are the only ones I could find with more conservative lift figures for the 1.6 magnum rockers. Don't want to smash my valve seals or have some piston to valve intercourse. BTW Marty at Utawesome was awesome. Great guy to deal with and he knows his magnums!
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
