Hello... i can say you need to try is setting the Closed Loop Compensation Limits down. In my case I pulled the distributor to find that the gear is pretty worn on the bottom leading edges of the teeth. It looks like I need to figure out a way to get my distributor depth just a little deeper. This would explain my jumpy timing.
