Replace the 0.040 intermediate fuel jets with 0.020 jets. That will knock 75% of the fuel out of the intermediate circuit. That should be a good starting point. Drive it a bit, see how it does and go from there. Do not go WOT until you have a good handle on what it is doing.
You might want to put a power valve in the front and jet down to 84 or so. That carb looks like it is set up for drag race only. Driving it on the street will kill your rings and eventually take the whole engine with it.
