I have a Dart with a 440. I am installing a new transmission. I think the previous owner had a converter and flex plate for a cast crank 440. All of my new components are for a internal balanced steel crankshaft motor. I want to make sure the crankshaft is steel. Can you tell from the rear flange. I am pretty sure this is a 1973 motor. Maltese cross on engine identification pad.
