This is a product of too small of a feed wire in gauge. Its called voltage drop. It is why the headlights are dim too at idle. Also all the connectors offer up a resistance too.
With the engine off voltage at the dome light is at 11 volts +/- 1 volt and when you put the 4 ways on you may see the voltage drop to 9 - 10 volts and then when the 4 way bulbs are out it will wink to the 11 volts again. But start the car and now the altanator is pushing 14.5 volts and that extra 2 volts does make a difference.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
Posting cheap tech help (CRAP) here since Nov 97, 1000's of posts, some may be good.
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
