I’ve adjusted the idle mixture screws a few times, makes no difference to the motor, can still screw them in all the way with no change to the motor. The vacuum is at 15-16, needle bouncing back and forth. The shop suggested that I have a vacuum leak and referred to the brake booster. I tested the booster according to a couple of YouTube vids and the booster seems like it’s ok per the tests.
