There should be no fuel flow through the main jets at idle so changing them wont make a difference ,When you take your bowls back off to change the jets back do a static check on your float level and that should put you in the ballpark. You might also want to check the power valve to see if its wet on the carb body side of the metering block.
Gus beer
64 Plymouth Savoy
493 Indy EZ's by Nick at Compu-Flow
5-Speed Richmond faceplate Liberty box
Dana 60
