Originally Posted by GY3
https://youtu.be/k7yWD_B6Nqw
Guess I need to throw away my adjustable front shocks and just drill holes in some Monroes. shruggy
LMAO , good vid. Back in 1986ish....i had drilled my front shocks on the duster i street raced. But we used to drill them drain out some oil then put a sheetmetal screw in the hole LOL. Then you "adjusted" the shock by adding or taking out oil. It did work good ....that duster won 40+ street races undefeated
....BAD A$$ STREET CAR.....
