Check the wiring connection at the bulkhead. Down by the steering column at the firewall. Remove it and clean the contacts. Then try again. If it starts now you want to really clean it up cause you’ve found the problem. The ignition feed on that terminal block carries a fair amount of current and is susceptible to failure over the years.
