Thanks P, is your lift directly in the center or off to the side? Do you put it higher to work on or can it be a little lower, enough room to park one car under the one on the lift? How hard was it to put together yourself? Here in GA, I don't think I would need heat in the concrete but would put something (foam board?) underneath plus some plastic for a moisture barrier.
