Originally Posted by Doc Fiberglass
Originally Posted by 5thAve
The owners manual only lists The V6 for towing they probably would void warranty if you had drivetrain problems with the other engines.
I tried a BACK DOOR way through the FCA parts dept to get “approval” !!
If they have a hitch available through the parts dept and there’s a listed charge for an install - THEN that might be acceptable. But nothing is available.
Does that make sense that a 6 banger would be allowed.... and a 5.7 or 6.4 would NOT BE?
The transmissions in the V8 cars have to be HD.
I’m not looking at doing ANYTHING heavy ... maybe a small boat or jet ski
There was a hitch available from Mopar back when I bought mine in 2010
It was for small stuff... maybe class I
V6 & 5.7 Auto only, but not 6.1
If you crawl under there and take a look exactly WTH would you attach it too? work
Not much in the way of solid metal in the last 2ft
Maybe people tore a few clean off the car and they stopped selling it. shruggy
SRT's weren't recommended for Towing.,,, not even the Jeeps. (Likely a liability thing)
Found this in the 2010 Challenger manual on towing.
TRAILER TOWING
Manual Transmission – If Equipped
Trailer towing with this vehicle is not recommended.
In this section, you will find safety tips and information
on limits to the type of towing you can reasonably do
with your vehicle. Before towing a trailer, carefully
review this information to tow your load as efficiently
and safely as possible.
To maintain warranty coverage, follow the requirements
and recommendations in this manual concerning vehicles
used for trailer towing.
Pages 320-332 deal with towing.... much of it generic & clearly not Challenger specific.
The text above & page below is... pic
