Thanks for the reply on the wires, as near as I can tell you are correct. I thought the change to orange was sometime in 73 and you supporting what I learned is another step to confirm that. Mecum does have my email and Thank You for the tip, I had seen that car listed, great idea and I will check it out Thanks. Terry great picture and info, it’s nice to see a b body. I can get a lot of info from that. I am surprised that air cleaner is black on a rally, I thought for sure it would have been orange. I do believe mine should be black, I’m putting together an SE, but I have been told it could have been either color. How about the negative battery cable, installed before engine paint or not? Thanks again to everyone, keep the info coming!!
