Originally Posted by fourgearsavoy
Most common cause is worn clutching teeth on the 4th (input shaft) and the 3-4 slider. I would first check the obvious shifter linkage adjustments but if it goes in solid but pops out as soon as you let of the gas it probably needs a new input and slider twocents
Gus beer
I agree
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
