Myself during testing I found that the 3/8 pipe will handle rpm up to and more than 8700 rpm... I normally
build my own pick up to fit my pans(all are custom pan).. the pan I run now will hold 10 qts plus the
filter and lines.. but I dont run that much oil in it.. but your 1/2 pick line looks good.. where did you get
it at with the cover
wave
